COMPLETED i need broken amps
Got a picture of the Soundstream? Might be interested in it as it is a older one and I am going to be doing a old school build in my Cutlass in 4 years so going to be looking for older stuff like that to put in it.
You can get that fixed at Amp Lab or any repair place. They will go through it and fix it. I would get it fixed as those are still nice amplifiers. Not too mention not cheap when they came out I remember the V2 going for around 350-450 dollars
Old School Amps. I have a few. laying around. S.Stream and few BTS series Spoken for ATM
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
111
183
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
137
488
Eaudio2013
Eaudio2013
wodokz
    May 19, 2024
    May 19, 2024
