2000 1st Gen Honda-CRV Headunit Installation Issues I CANT FIGURE OUT WHY THIS WONT WORK
  • 2
littlepoppa
2000 1st Gen Honda CRV Headunit Installation Issues​
I will attempt to keep this as short and to the point as possible... I NEED HELP this is driving me crazy hahah
Here is the headunit that I bought for a 2000 1st Gen Honda-CRV: https://www.amazon.com/dp/B0CLD2P6Q3/?tag=caraudiocom-20
Here are my issues...
1:
The headunit came with a prewired harness that fits the existing car connection BUT.... when I connect it to the car nothing happens. It wont turn on. This should be simple plug and play, am I wrong to think this?
2: Because the pre wired harness was not working I bought a wiring harness compatible with a 2000 Honda CRV and snipped the prewired harness and then rewired as followed in an effort to troubleshoot:
Here is the harness I bought: https://www.amazon.com/dp/B004W34BOW/?tag=caraudiocom-20
Yellow = 12v constant power
Black = GND
Red = Ignition
and then the remaining speaker wires to the correct corresponding wires on the harness....
After all this STILL NOTHING....it wont turn on.
3:
This is more of a question than an issue but the black GND wire is split (I havent seen this before) one side of the wire is thicker than the other and that is what I used to connect to the harness, the other thinner end of the black wire I capped off. What does this mean? Anyone know why it is split? Could this be a reason why its not working?
Any help or guidance with this is GREATLY APPRECIATED I need to get this to work ASAP. The only thing I havent done is check connections with a multimeter, I plan on doing this....
THANK YOU ALL!!!!! SO SO SO SO MUCH!!!!!!!
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick test, connect the radio direct to the battery. Both Red and Yellow twisted together. Make sure all other wires are not exposed.
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
The last piece and the system is a wrap, RUX-H02 remote volume/sub knob because we are old and buttons **** IMG_0647 by Jon Polo, on Flickr...
  • Locked
Why? Because of the owner? The cheaper won't be as clean as the SIA.
21
4K
littlepoppa
littlepoppa
Illinois
    May 19, 2024
    May 19, 2024
