RF are good amps, bit overpriced in my book, but well made as are JL. But that Jp77 is a beast fo sho! Lots of great Korean board amplifiers out there, no reason to limit yourself to one brand.
True. I do miss US Amps Barbara Ann. Man that thing sounded good!!!
Believe it or not, this 4 channel marine Soundstream Rubicon Nano sounds great too... Guess what, also a Korean amp.
I've seen some interesting comparisons on the Smart and the Smart BASS for sub use, If I was to choose, thinking the SMART BASS would the Taramps I would consider.
If you're wiring to .5 the bass version is the ticket but outside that it's half a dozen in one hand and six in the other kind of thing
I got the little BASS 400 on my test bench and it actually pounds the $hit out of a set of 12's and barely gets warm! Pretty amazing what these little things will do.
Have to remember only about a 4-5 db increase in volume from 1000 to 3000 watts, not a huge difference.
1000 to 2000 3db
2000 to 4000 another 3 db
4000 to 8000 another 3db
So, one has to go to 9000 watts to double the volume from 1000 watts, pretty steep hill to climb.
Weird that you mention Techmaster. I was pounding Techmaster when it kept shutting off. Bass Computer!!!
Maybe try backing your gain down some and see if it does it again. Personally I'm not sure how much I trust the clip light to be 100% accurate
Check out machines 2020...it's amazing 🥰
427
521
677
720
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
    May 31, 2024
    May 24, 2024
