alphakenny1 10+ year member
LOTUS FTW!
I’ve noticed there have been a lot of questions regarding the differences between active and passive crossovers. I am going to attempt to explain the differences between the two and also the advantages and disadvantages of both. I’m not going into a very detailed technical explanation, I just want a basic explanation for the people out there who don’t know the difference between the two.
Just some terms to know before reading:
Low pass filter
A low-pass filter is a filter that passes low frequencies well, but attenuates (or reduces) frequencies higher than the cutoff frequency.
High Pass filter
Exactly the same as a low pass filter but passes high frequencies.
Bandpass Filter
Is a combination of a low pass filter and high pass filter.
Octave
An octave is doubling the frequency. For example going from 50 Hz to 100 Hz is one octave. Going from 50 Hz to 200 Hz is two octaves, ect…
Crossover slope or roll off (reference http://www.bcae1.com)
Crossover rolloff (or slope) describes the rate which the audio level increases/decreases per octave as the frequency increases/decreases. Usually a crossover slope is given as 6db/octave, 12db/octave, 18db/octave, 24db/octave, etc. If you want to see a visual of this here is a great picture:
Cyan = 6dB/octave
Red = 12dB/octave
Green = 18dB/octave
Violet = 24dB/octave
As you can see the different types of slopes and also notice that the crossover point is 1k.
Crossover Point
This is where frequency where the roll off or slopes starts to begin. As with the picture from above the crossover point is 1 kHz roll off begins at that frequency.
2 way crossovers
These crossover have two difference types of crossovers: Low pass filter and high pass filter.
3 way crossovers
These crossovers have three different sets of crossovers: Low pass filter, bandpass filter and high pass filter.
Low pass filter
High Pass filter
Bandpass Filter
Octave
Cyan = 6dB/octave
Red = 12dB/octave
Green = 18dB/octave
Crossover Point
2 way crossovers
3 way crossovers
