Fs) Digital Designs amps, 3 m3as and 2 m2as, **VIDEO VIDEO VIDEO!!!***
cdimic25
2 New M3a
1 Used M3a
2 New m2a
The M3a has been our most popular high powered amp for many years. The M3 was never designed for spec power, but was one of the first amps in this power range to utilize a high capacity quad power supply and rock solid output section. The M3a continues the tradition delivering over 3000 Watts of long term, SQ quality, RMS power at alternator charging levels. The M3a has been the go-to amp of choice for high performance sub systems.
Here are DD's Conservative specs...
Bridged NA
Channels 1
Cont Power at 1 Ohm 2200W x 1 @ 12v
Cont Power at 2 Ohm NA
Cont Power at 4 Ohm NA
Damping Factor NA
Dimensions (Inches) 21.5L x 9.13W x 2.5L
Dimensions (Metric) 546.1L x 232W x 63.5H
Dynamic Power 4000W x 1ch
Efficiency Thru Output 87%
Input Sensitivity 0.15V - 5V
Shipping Weight 21 lbs
S/N Ratio >100dB
Tested THD ≥1%
Tested Voltage 12v -14v
Variable Bass Boost 0-6dB @ 45Hz
Variable High Pass Filter NA
Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct
$650 Shipped obo for New M3a
$575 Shipped obo for the used M3a (it has 0 marks on it its perfect!!!)
$450 Shipped for m2a
USPS, they need the money so i use them!
Item Pictures: http://www.youtube.com/watch?v=rjyMLvaJniw&list=UUoPctu88Gg9By-MS-7U-h4A&index=2&feature=plcp
i have a question I'm running one 2510 dual 4ohm , now I have 800 watt infinity kappa one, but It's simply not enough power.
Now im questioning is an m2a @ 2 ohm going to give me at least 1200-1400 watts @ 14.v?
or should I just get an M3 if i'm only running it @ 2 ohms.
i know m3 for only one sub is a shame but i'm not sure if i want to do dual subs
i have a question I'm running one 2510 dual 4ohm , now I have 800 watt infinity kappa one, but It's simply not enough power.Now im questioning is an m2a @ 2 ohm going to give me at least 1200-1400 watts @ 14.v?
The m2a will do just about what you said if not a little bit more. If you plan on expanding, the m3a will bring on huge possibilities at lower ohm loads.
BTW WE HAVE THE M2AS AND USED M3A
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
cdimic25
cdimic25
SPL KID
maylar
    Jun 2, 2024
    Jun 1, 2024
