Is there an emulator module to connect external CD players to '22 Honda head units?
Valdric
I just bought an external DVD drive, an LG SP80NB80, to play music CDs via a USB port in my 2022 Honda Insight head unit (which has two USB ports but lacks both a CD player and a 3.5 mm auxiliary port).
I bought it because the LG SP80NB80 is known to play CDs on a 2017 Honda CRV, but although my head unit will recognize the drive and the CD's music files (not by name, just by a generic label) when plugged into either of the USB ports, it won't play the music files on 4 different CDs.
So, can anyone direct me to a USB emulator module that will accept the DVD drive's USB cable on one end and, with a second USB cable connected to the other end, send a converted/readable signal to the Honda head unit?
I've checked Honda and Insight forums and have continued to look for solutions, but I can't find anything that would allow me to plug a CD player into the car's USB port and play CDs. I did find an older FM transmitter car adapter with an auxiliary port that will send music to the radio, so that's likely to be my only solution, which is fine.
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I see a couple "Wanted To Buy" AC206 threads on here. There's a new one on eBay right now...
I assume the plugs are if you have factory equipment like a amp, etc.
954
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
Valdric
Valdric
Little Rock, Arkansas
Valdric
    May 18, 2024
    May 18, 2024
